Identify the Oil Leak
Old May 10, 2012 | 12:46 PM
hxgaser's Avatar
Originally Posted by shipo
Guys, the timing chain tensioner gasket and the half-moon seal are under the bolted in place timing chain tensioner. Like it or don't, believe it or not, unless you can produce Audi documentation which says otherwise, you MUST remove the tensioner (which also means removing the cams) to get at the gasket and seal.
No. Audi tech document says you have to remove the cams, but if you are sneaky like me, then you can replace the seals without removing the cams. You do need to compress the tensioner and remove the tensioner bolts. You can use a small pick to remove both the tensioner gasket and the half moon seal. Use anaerobic gasket seal on both the gasket and the half moon seal and slide it back in.
Melchizedek
May 3, 2013 01:23 AM
sabresfan
Sep 18, 2012 12:01 PM
Aud1A4
Jan 29, 2011 02:24 AM
plakasc
Jul 4, 2007 11:36 AM
jwellyman
Nov 13, 2006 02:17 PM
