Idle question
Old Oct 1, 2008 | 07:27 PM
fox3inbound's Avatar
Default Idle question
My 2001 Audi A6 Quattro, 2.8 began idling a little rough. When the car is being operated on the highway, or around town, it runs fine. When I stop the car begins to idle below 1k and jumps up and down slightly. I was able to have it put on a generic computer which indicated a multiple cylinder misfire on bank 2. I just had the oil and spark plugs changed, but it still acts the same way. I was told that it might be either the camshaft position sensor or the timing chain tensioner. Any ideas?
Old Oct 1, 2008 | 11:39 PM
oc_audica's Avatar
could also be a dirty throttle body, dirty maf, or a broken vac line... which are all kind of common.
Old Oct 1, 2008 | 11:44 PM
ryuuoh's Avatar
check your plug wires. open the hood, take off the covers and turn off the lights, look for sparks.
could be coils too.
Old Oct 2, 2008 | 06:39 AM
Kevin's Avatar
I am betting that it is the coil packs.
Old Oct 2, 2008 | 10:48 AM
Thank you I will start there and re-post after I check them.
Old Oct 2, 2008 | 01:22 PM
Ok.. I found these codes..
P0345 Cam Position Sensor
P0300 Random/Multiple Cylinder misfire detected
P0304 Misfire detected Cylinder 4
P0305 Misfire detected Cylinder 5
P0306 Misfire detected Cylinder 6
Also, the MAF, throttle body, and vacuum lines are all clean and functional. I also took the coil pack off and there was a small cut in one of the wires. I hope someone can guide me in the right direction here.. I really hope it's not the Chain Tensioner.
..Also I was told by an audi mechanic that running conventional oil may cause a sludge build-up on the tensioner, which is why it doesn't idle normal and acts fine at higher RPMs. It was suggested that I change the oil to full synthetic, which I intend to do today.
Thanks in advance for your help
Old Oct 2, 2008 | 03:41 PM
CrazyEights's Avatar
yea, those are the same codes my car threw pretty much but in a different cylinder order of course... oh yea, and don't run conventional oil... seems like a bad idea for our cars... 5w30 or 0w40 should do the trick. im not sure what area you're from but if you're in MD, go to Pro-Imports in Rockville or Induktion Motorsports in Columbia and they should be good options.
Old Oct 2, 2008 | 07:06 PM
I live in Colorado.. actually the coldest spot in the nation. It got forty below last winter, good thing I have a garage. So anyway I put synthetic oil and ordered NGK plugs. It's already idling better. It's still not 100% though. So what, exactly, did you do when your car gave you these codes?? Thanks for the help CrazyEights..
Stratochief
Jan 27, 2010 08:52 AM
AudiVirgin
Sep 19, 2007 02:08 PM
itsnumb
May 22, 2007 11:57 AM
loochie
Jul 25, 2006 03:32 PM
blka4man
Feb 15, 2005 04:02 AM
