Ignition sticking... help!
Old Aug 23, 2008 | 07:11 AM
zrooster99's Avatar
Default Ignition sticking... help!
Hello to everyone! I've got a 96 A6Q that has a sticking ignition. Usually when I start the car, I have to back the key off of the start position just to turn off the starter and to turn on the a/c and whatnot. My buddy insists that the problem is the the key and tumber itself, while I feel that it is probably an issue with the ignition switch itself. Obviously there is a price difference between the two (actually, in my podunk little town, I can't even get the key and tumbler!) So what is it... the tumbler or the switch? How difficult is it to change the switch? And are there any how-to's online for this? Thanks so much!
Old Aug 23, 2008 | 11:47 AM
ryuuoh's Avatar
sounds like the ignition switch. get a new one at the dealer.
Old Aug 23, 2008 | 10:39 PM
zippy_gg's Avatar
I had a very similar issue with my 97 A4 2.8 and there was a recall on the ignition switch so you want to call a dealer and give them your VIN.
Mine was replaced for free as part of the recall.
Old Aug 24, 2008 | 12:34 PM
AbingtonJim's Avatar
Default Ignition Switch
Get a new ignition switch FROM THE DEALER, no part store cheap part. New from dealer is about $30. It takes about 45 minutes to an hour to swap it out. Tools needed are a Phillips screwdriver and a small (2 mm ) jewelers screwdriver and some locktite. You'll have to take out the instrument panel (Phillips) and then find the ignition switch and loosen the two small screws (2 mm) on the switch, remove the wiring connector and slide out the old switch. Installation is the reverse and don't forget to use the locktite on the small screws.
Dealers charge 2 hours labor + parts.
Old Aug 24, 2008 | 10:16 PM
adidasallstarguy's Avatar
do you know how the wire connector comes off? My dad and me are having quite the time getting it loose. your post did help just if you could tell us how to do this maybe we can get it,thanks alot.
Old Aug 25, 2008 | 07:37 AM
Default Switch
Connector is a very tight fit with multiple prongs to prevent misalignment.
Old Aug 26, 2008 | 03:17 PM
zrooster99's Avatar
I like in Podunk Ohio, so I won't be taking it to the dealer
So basically pull out the instrument panel, and find the switch? Sounds like a pretty easy job?
Old Aug 27, 2008 | 12:37 PM
zrooster99's Avatar
Fixed! Just replaced that ignition switch, and she works like new... it was a bit of a hastle, but we got it... thanks for everyone's help!
aurbablue09
B8 Models
Mar 9, 2009 06:27 AM
eldrego
Mar 3, 2009 01:00 PM
RedTTQ
Dec 29, 2006 03:55 AM
RedTTQ
Dec 21, 2006 02:27 PM
AUDIJOHN
Jun 3, 2006 01:33 AM
