Installing new head gaskets A6 3.0L
Old Oct 3, 2010 | 11:54 PM
02AudiA63L_65's Avatar
Default Installing new head gaskets A6 3.0L
Can anyone tell me if they used Indian Head gasket compound on the new head gaskets?? Any issues when applied?
Do I apply the compound on ALL surfaces - block, gasket, and heads??
Old Oct 4, 2010 | 01:54 PM
bob martin's Avatar
Don't use ANYTHING on a head gasket. It comes with everything it needs. Make sure both surfaces are CLEAN. I scrape them, run a file over them, wash them with alcohol then spray them with brake cleaner. Make SURE to clean out the bolt holes by running an old head bolt coated with light oil all the way down in them. Make sure to run your head bolts down to spec in the sequence specified (center bolts first then work your way outwards) and in two steps.
Bob
Old Oct 4, 2010 | 10:16 PM
Bob,
Thanks for you help!
Jim
chefro
Mar 15, 2016 11:02 PM
erk187
Oct 28, 2010 09:29 PM
brian58503
Apr 19, 2009 11:56 AM
tradesmith45
Sep 29, 2008 02:46 PM
CaliA4
Feb 6, 2005 02:47 PM
