Intermittent Rough Idle in 2.7T
Old May 1, 2009 | 01:42 PM
KiserRN1981's Avatar
Exclamation Intermittent Rough Idle in 2.7T
Calling all Techs. I have an intermittent problem with rough starting idles. This happens every few months, more often when cold or wet. There has never been a CEL, so no codes. The problem always resolves within one to two miles of driving. It is characterized by a rev to about 1500rpm followed by a low rev (700rpm or so) almost choking out then another high, and persists until car is warmed up a little. I have read that it could be an ICV, but I don't see one listed with 2.7T parts. My other thought is the MAF, but this would trip the CEL I thought. Any help would be appreciated.
Old May 2, 2009 | 08:46 AM
mlwartman's Avatar
idle air control valve would be one place to look at it, but i'd vacuum test and look for leaks. i get the same thing from time to time, and mine finally popped a P0301 code when i let it sit and idle while it was stumbling, but i'm assuming you've already thought of plugs.
DrJb
B8 Models
Jun 5, 2015 08:31 AM
justinclarke
Nov 25, 2010 04:03 PM
Yentemad
Apr 24, 2008 04:47 PM
