koni FSD & new member
I am a new member to this forum , yet have owned many audis.
Last week I did a CV joint replacement & installed koni FSD;s .
My car is a 2000 2.7 6spd with the sport package & aftermarket swaybars.
the change in the ride is fantastic. All the little pot holes are gone. It is like riding a few inches off the road. Car is also stiffer once you get into sweepers. Great shock for a sport cruiser, on my smaller sportier cars (BMW)I have bilsteins. Which are firmer all over.
Also while installing the CV boots ,I found a short cut to help seperate the drive axle from the joint. I removed the 17mm hex bolt & put 1/4 ' deep socket in the hole to act as a spacer put the bolt back in and that allowed the spline from the axle to seperate from the joint.
RE: koni FSD & new member
yes the car has the factory sport suspension. The car also seems quieter. I don't want to give the impression that these are a comfort item , they are definitely sporty, but not jaring like a bilstien would be. Car also has Hotchkis bars.
When I did this work I took my 17' summer tires off & put on my 16' winter tires so that will also make a difference in the feel.
