Sponsored by:
Sponsored by:
koni FSD & new member
Old 12-11-2007, 03:39 PM
michaelF's Avatar
Default koni FSD & new member
I am a new member to this forum , yet have owned many audis.
Last week I did a CV joint replacement & installed koni FSD;s .
My car is a 2000 2.7 6spd with the sport package & aftermarket swaybars.
the change in the ride is fantastic. All the little pot holes are gone. It is like riding a few inches off the road. Car is also stiffer once you get into sweepers. Great shock for a sport cruiser, on my smaller sportier cars (BMW)I have bilsteins. Which are firmer all over.
Also while installing the CV boots ,I found a short cut to help seperate the drive axle from the joint. I removed the 17mm hex bolt & put 1/4 ' deep socket in the hole to act as a spacer put the bolt back in and that allowed the spline from the axle to seperate from the joint.
Old 12-11-2007, 03:49 PM
auditech79's Avatar
Default RE: koni FSD & new member
Welcome to the forums, and good job.
Old 12-11-2007, 05:27 PM
alias747's Avatar
Yes WELCOME! Did you use the FSD's with just your stock sport springs?
Old 12-12-2007, 10:02 AM
michaelF's Avatar
yes the car has the factory sport suspension. The car also seems quieter. I don't want to give the impression that these are a comfort item , they are definitely sporty, but not jaring like a bilstien would be. Car also has Hotchkis bars.
When I did this work I took my 17' summer tires off & put on my 16' winter tires so that will also make a difference in the feel.
quadric
07-23-2007 05:09 PM
quadric
07-23-2007 10:41 AM
ouTTie914
05-24-2007 09:32 PM
AudiOso
05-11-2007 05:32 PM
rons01a4
10-23-2005 04:02 AM
Quick Reply: koni FSD & new member
