Leak Problems any help??
well i just found this out..i noticed that the car i bought last week which is a 98 audi a6 2.8, keeps telling me i am low on window washing fluid meanwhile i put in a whole gallon. i heard it leaking and noticed that the leak is coming from the washing fluid container. i am wondering where can i order a new container and is it hard to remove the old one and install the new one? i am no mechanic but eager to learn
Mine has been a bear since repairing the ABS module as I had to drop the reservoir to make room. I know for a fact that my gasket is not on properly. You may just need a new gasket or gasket seal as opposed to a new reservoir tank.
The first thing you'll need is a decent jack. The stock Audi one is a POS. Advanced Auto Parts has some for about $40 or so. As mentioned above you'll need to remove the wheel and inner fender liner. I would try to replace the grommets first to see if that's the problem. The total set is about $6 or so. You may also want to get plenty of silicone sealant as a cheap repair.
Good luck,
Mike
Good luck,
Mike
thegreatgate
Apr 28, 2012 04:57 PM
