Leaking Antifreeze on my 4.2?
Old Feb 9, 2007 | 12:23 PM
Ice Train's Avatar
Default Leaking Antifreeze on my 4.2?
So I have had no real problems my my 2001 4.2 until recenlty. About a few weeks ago when it started to get extremely cold my dashboard light came on for low antifreeze. Well I put some in about a week ago and this morning it came on again, I checked and sure enough it is way too low but it took about a week to get to that level. Any ideas on where the leak is and how much it will cost? Is there anything I can do so I can avoid the stealership?
Appreciate the help.
Old Feb 9, 2007 | 01:55 PM
jonny29's Avatar
Default RE: Leaking Antifreeze on my 4.2?
Same thing happened to me about a month ago. I was loosing a lot of coolant out of my 01 4.2 and also the smoke would rise from the front of the car. I took it in to the dealership and the mechanic called me a few days later. I was told my oil cooler was leaking and that it was possible that there was a leak in the coolant reservoir. So they changed the oil cooler and its been great for the week that ive had it back. Try looking into those 2 locations because your problem sounds exactly like mine did.
Hope this helps
Old Feb 9, 2007 | 02:03 PM
Ice Train's Avatar
ORIGINAL: jonny29
Hope this helps
I don't have the smoke just the leak so far. How much did your work cost?
Old Feb 9, 2007 | 02:11 PM
jonny29's Avatar
Sorry, it wasnt really smoke, it was the antifreeze hitting an extremely hot engine part and it would create the nastiest smelling steam. I had a lot of things done to the car at this time and it was all under warranty. As far as I can see there was a new seal added for $4.45, and a M-bracket that was 458.00. If you go to a dealership they are gonna get you, I only went since I have my warranty. I would say go to a reputable shop and have them do a radiator pressure test and that will tell you where its leaking. Id say a good euro car shop should get you for too much, unlike the dealer, which looks like they would of gotten me for easliy over $600 for this problem.
whit123
May 28, 2013 10:42 PM
JabberwockyD
Apr 19, 2011 08:04 AM
ultrasport
Feb 9, 2009 12:43 PM
skyers28
Dec 15, 2006 01:41 PM
skyers28
Nov 6, 2006 11:04 PM
