Limp Mode
Old Jan 23, 2006 | 12:25 AM
Ety's Avatar
Ety
Default Limp Mode
I was looking at some classified ads and I saw some cars that are in "Limp Mode" What exactly happens, and how is it usually fixed? Thanks
Old Jan 23, 2006 | 02:53 AM
ChicagoA62.7t's Avatar
Default RE: Limp Mode
yeah i have an 02 2.7t and i was also wondering this, how can you tell its in limp mode, and how do you fix it?
Old Jan 23, 2006 | 08:27 PM
AudiTech04's Avatar
Limp mode is usually a problem with the tranny
You would be able to tell if this was going on
Old Jan 23, 2006 | 08:30 PM
i think mines in limp mode, the car jerks sometimes from 1 to 2, and it vibrates on drive when your stending still, i took to audi and they said it was normal but its doesnt seem right
Old Jan 23, 2006 | 08:35 PM
AudiTech04's Avatar
Is the PRNDS display lit up
If not your not in limp mode
Old Jan 23, 2006 | 08:37 PM
yeah its lit up, you mean in the middle in red letters, below the info screen
Old Jan 23, 2006 | 08:41 PM
techbod's Avatar
codes have to be checked from the ECU/ECM to determine the fault, limp mode is when the system shuts down to prevent damage to any system a better name is "safe mode", limp mode can happen to a transmission and the injection in fact any system that run by a computer
Old Jan 23, 2006 | 08:45 PM
there were codes they took them off and refilled the trans fluid, and said that should fix it, i'm taking it a diffrent place to have it looked at again... is it normal for the whole car to shake to the point where the headlights wobble, it doesnt seem right to me but they said it was fine
Old Jan 23, 2006 | 08:47 PM
Ety's Avatar
Ety
The A6 I am looking at, the owner says the trans was replaced recently. But now it goes in and out of limp mode and the RPMs go down and the speed goes to 35mph. What do you guys think would be causing it? Could it be fixed for less then a few hundred dollars?
Old Jan 23, 2006 | 08:54 PM
techbod's Avatar
the car will shake violently as it cant get the required information from the ECU because its shut down so it will idle real bad and that's normal in limp mode, without a code I can only guess the fault and its not worth guessing it could be many things
