Lock doors without key
Old Jun 22, 2009 | 06:44 PM
Namenone's Avatar
Default Lock doors without key
So basically, my mum took the keys with her and i just noticed that one of the doors is unlocked.
Does anyone know how i can lock the door without a key? Ive tried to push down the door lock and close it, but it just pops up again. Any ideas here?.
2003 model
Old Jun 22, 2009 | 11:28 PM
james0013's Avatar
is there not a lock button on the inside of the drivers door, get in through the unlocked door, get into the drivers seat, get out of drivers door, press the lock button next to the door pull inside close door and walk away.
car locked
Old Jun 22, 2009 | 11:35 PM
Jackmup's Avatar
LOL, Sort of like when you loose the remote control and spend 30 minutes looking for it because you don't want to turn the TV on by hand.
I must admit, been there, done that
Old Jun 23, 2009 | 12:07 AM
Jeffla's Avatar
car locked
Go outside and try that yourself. You clearly haven't owned a european car before. If you press the lock button on the drivers door with the drivers door open, it will lock all the doors but the drivers door. You also can not manually press down the drivers door lock with the drivers door open.
To the OP,
with the drivers door closed, press the lock button, get out of any door other than the drivers door and press the lock button manually.
Old May 19, 2013 | 05:52 PM
dsarnes's Avatar
I just encountered this issue. I took my 02 TT Quattro in for a clutch job (cringe), dropped the key in the drop box and realized my car was unlocked.
I got around the issue by opening the rear hatch, crawling over the rear seats, hitting the lock button and crawling back out the hatch. The motion sensor has a delay so it will not alarm if you hurry and crawl out after hitting lock. Once you close the hatch, the car locks.
luis_16_r
May 12, 2013 10:14 PM
tighr
B8 Models
Jul 9, 2009 07:37 PM
kitmattson
Dec 17, 2007 05:26 PM
ricscars
Dec 6, 2006 04:52 PM
ned8me
Oct 19, 2006 07:52 PM
