doors wont lock!!!!
Old Mar 28, 2012 | 12:24 PM
luis_16_r's Avatar
Default doors wont lock!!!!
My car won't lock at all , even wen I try with the key . The only way it.locks is when I'm inside the car with the doors closed . Please help
Old Mar 28, 2012 | 02:08 PM
M5S5's Avatar
Tech Certified
Luis , seems like you have a few problems with your car. Did you check under the drivers carpet for water yet?
Old Mar 29, 2012 | 08:46 AM
luis_16_r's Avatar
Nah not yet , I will do that . Is there a good spot to do that where I should check or anywhere in the car is a good spot . If it doesn't matter what is the easiest spot.
Old Mar 29, 2012 | 09:30 AM
M5S5's Avatar
Tech Certified
Right in front of the drivers seat. There is a 2" foam pad attached to the underside of the carpet & a black plastic box containing your comfort module.
Old Mar 30, 2012 | 08:05 AM
luis_16_r's Avatar
I will take a look this weekend and let you know. Thanks
Old May 12, 2013 | 10:14 PM
pelletman's Avatar
Did you get that problem figured out? I have similar issues. Have not looked for water yet..
A4driver17
Apr 22, 2015 03:05 PM
RAE0694
Jun 28, 2013 06:41 PM
moneyfresh
Jun 10, 2012 09:41 AM
mm107
Aug 23, 2007 10:48 AM
