Low engine coolant temperature
Old Jun 11, 2008 | 12:42 PM
SloRide's Avatar
Default Low engine coolant temperature
I have a 96 with the 2.8 and recently the engine coolant temp was reading low ( barely getting off the lowest reading). Several searches talked about the coolant temp sensor on the coolant pipe, back of the engine, passenger side. I located it and just for the sake of elimination I pulled off the connector sprayed on some contact cleaner on it and the sensor and BINGO! thegauge was back to reading the correct temperature. Lucky I guess but something to check before you go thru replacing the sensor.
fergusjk
Sep 10, 2012 08:35 AM
Pablo_Ottawa
Oct 5, 2010 08:05 PM
nickgakis
Dec 5, 2008 06:57 PM
TnhW3218
Oct 15, 2008 02:40 PM
ONIROI
Mar 5, 2007 10:54 PM
