lower rear control arm help!
Old Sep 27, 2014 | 04:25 AM
RicksAUdi4.2's Avatar
Default lower rear control arm help!
The bolt that holds the lower control arm to the subframe doesn't have clearance to come out. I got the nut off and pulled the bolt as far as it would go but the head of the bolt is hitting the frame, and about to hit the fuel lines before it will have clearance to come out all the way.
I was thinking about just cutting the bolt (its really lose slidding in and out just hitting the frame before it comes out all the way). But once I do that how will I get the new one back in? I feel like who ever put the bolt in should have but the head of the bolt towards the center of the car instead of facing outward.
Any suggestions?
Old Sep 27, 2014 | 04:10 PM
Ok so I'm looking at it right now, it looks like it would be possible to remove the 3 sub frame bolts holding the bracket, this way I can extract the bolt at an angle....looks rather difficult.
If anyone has any other ways of doing this input would be great.
By the way, the car is on Jack stands. so I'm laying on the ground doing this.
Old Oct 1, 2014 | 05:44 PM
Huskerbob's Avatar
IIRC you need to loosen the subframe bolts or even take them out so you can get room for the bolt removal. Don't worry, the engine won't drop on your head at least I hope not.
Old Oct 4, 2014 | 06:45 AM
aspen79's Avatar
Like Huskerbob said, you need to remove the rear two subframe mounting bolts and LOOSEN the front two. Put a jack under the rear of the subframe when doing this. Lower the frame down. You may still have to pry it down far enough to get the bolt out but it WILL come out. Do not remove the front subframe bolts (only loosen a few turns) or the the whole works will come down.
Old Oct 8, 2014 | 05:54 AM
PelzoT's Avatar
You have to do what you have suggested!
I had the same problem, and the only way to deal with it is keep cutting the bolt until it's short enough to pull out. then put it back so that the nut is the opposite side of what it was. Then tighten the bolt into it.
dave944
May 3, 2015 07:50 PM
4mymalamute
Nov 5, 2013 02:25 PM
dave944
Aug 19, 2013 09:48 PM
mtroxel
Jun 14, 2012 10:48 PM
akielb
15
Mar 11, 2009 09:50 AM
