Manual Trans 2nd Gear problem
Old Oct 8, 2010 | 02:13 AM
03a6MTJake's Avatar
Default Manual Trans 2nd Gear problem
Hello everyone. I recently changed the clutch on my '03 a6. since then i started having problems. when i put it in 2nd gear and start releasing the clutch, the gear pops right out into neutral (not always but only in crucial moments like on a hill, or when i need to speed up fast) is this adjustable? or is it a serious tranny problem? any help would do, thanks.
Old Oct 9, 2010 | 08:30 AM
bob martin's Avatar
Did you remove the transmission during the clutch change? If so, double and triple check the shift linkage. Make sure it isn't hitting something that is stopping the shifter from going all the way into the second gear position.
Bob
ryal
B8 Models
Dec 14, 2013 05:42 PM
cseifer
Jun 4, 2010 05:19 PM
mel23816
Apr 8, 2008 07:26 PM
mat.martins
May 15, 2006 04:01 PM
MadIce
Jul 20, 2005 03:22 AM
