Mirrors
Old Nov 15, 2009 | 05:50 PM
xewax's Avatar
Member
Default Mirrors
There has been a post about the programed mirrors but i cant find it. Lets say you drive back your mirrors tilt down. Any help how to do that would be great. I would like to code with vag com and check if it works.
Old Nov 15, 2009 | 06:00 PM
Jeffla's Avatar
If you put the window adjustment **** to the passenger side of the car, when you put it in reverse is "should" drop. Mine of course has never worked fwiw. Our 3 series does the same thing and to be honest, I hate it. I would rather see what's next/behind the car than the ground. I already know where the curb is, what I don't know is how close I am to another car in the driveway.
Old Nov 15, 2009 | 06:25 PM
chefro's Avatar
Originally Posted by Jeffla
I would rather see what's next/behind the car than the ground. I already know where the curb is...
I second that. Mine doesn't work either, but I didn't even bother to look into it.
Always had the passenger side mirror low enough to see the ground next/behind the car, since that's the area you want to "scan" when you back up. The feature in discussion is just one extra electronic enhancement to keep you worried if it goes bad....
How many seconds does it take to adjust your mirror in a position where you can see perfectly where you back up, and forget about it?
(On top of everything else, all the "grease" from the fingers can dull the luster on the ***** over time from so many pushes/touches. Then you need to ask Jack about how to paint your interior )
Old Nov 16, 2009 | 01:01 AM
xewax's Avatar
Member
You say that there may be problems after coding it?
BFlan2001
Aug 31, 2009 01:14 AM
icepl
May 2, 2009 06:36 PM
bluemoon07
Nov 30, 2007 09:38 AM
rcons
Apr 20, 2006 04:23 AM
blever
Mar 6, 2006 04:10 PM
