MISSING: 1 Cabin Air Filter Cover for 2000 A6
Old Sep 19, 2011 | 08:41 AM
carelm's Avatar
Originally Posted by OGBULLYLOCDAWG
Top left (passenger side) near the windshield. Remove that plastic cover and it'll be sitting right there.
Adding to comment: you don't even need any tools. Just remove the rubber stripping that secures the plastic cover and then slide out the cover. The cabin filter is pretty easy to get to. Also, the a/c high and low pressure lines are accessible if you need to recharge the a/c.
Old Sep 19, 2011 | 10:28 AM
badinstincts's Avatar
Originally Posted by CRuby
Here's some pics with the fender-fender cover removed. Cabin air filter sitting right there on passenger side. Thanks guys for the no-cover info. While I was there, pulled out the battery & battery tray & cleaned out the drains. One was completely clogged & the other was on it's way. Now onto the sunroof drains.
I read a service bulletin or something from Audi a couple of days ago, about the drains under that cover, there should be like a piece of rubber around the drain, grommet, they say to take it out because it can get clogged and cause the brake booster/battery to flood in heavy rain.. So it wouldn't be a bad idea to get rid of it in case of a freak storm...
Old Sep 20, 2011 | 05:14 PM
alternety's Avatar
It sure does clog. Floods that compartment (including the non-waterproof main computer) and then the cabin air filter, and then runs into the HVAC system and into the cabin. What a deeply stupid place to put a small drain.
Old Sep 20, 2011 | 08:56 PM
CRuby's Avatar
Tried to increase size of my prior picture showing filter location & the 2 drain locations. I've read that some people have had both drains blocked & water sloshing around & getting into electronics below passenger carpet region.
Attached Thumbnails MISSING: 1 Cabin Air Filter Cover for 2000 A6-under_cover.jpg
RickA6
Sep 28, 2016 11:19 PM
janaya680
Jun 5, 2014 04:04 PM
911c4lover
Jul 2, 2012 09:22 PM
elburko91
Mar 22, 2011 07:27 PM
911c4lover
Oct 11, 2005 05:46 PM
