n00b mistake...valve cover gaskets
Old Jun 21, 2010 | 06:55 PM
jwd2a's Avatar
Default n00b mistake...valve cover gaskets
I replaced my valve cover gaskets and cam tensioner seals a couple months ago. Still, the car is smoking and leaking oil, and I've been wondering why that would be.
I realized recently that when I did the gaskets, I didn't wait for the silicon sealant to dry. In fact, like an idiot, I put it back together, took it off the ramps, and immediately went driving around.
Two questions:
1. Would driving right after reassembly, without letting the sealant dry/cure, cause it to blow past the sealant and leak?
2. Is it possible to reopen the cover, reapply sealant, and let it cure now? Or (and I think this is the answer) will I need to get a whole new gasket set and start over?
BTW, I used Permatex HI-Temp RTV Gasket Maker (not "Gasket Sealant") - was that a bad choice?
Thanks!
Justin
Old Jun 22, 2010 | 07:45 AM
Theiceman's Avatar
I hate all that stuff , a piece breaks off and goes into your engine and blocks a journal your engine is toast. That being said you should be able to remove the cover and redo it . Just clen your cover and gaskets thorughly with brake cleaner to remove any residue. like most things a good job is in the prep work
Old Jun 22, 2010 | 07:54 AM
oldmots's Avatar
The gaskets should be put on dry after wiping ALL the mating surfaces with acetone or lacquer thinner to completely degrease them and leave NO residue. Like Iceman, I never use RTV on engines unless there is absolutely no choice. Since the valve covers on the newer models are plastic, I would go easy on the solvents so not to melt them.I don't like glue of any kind. If you are blowing a lot of oil past the gaskets, be sure the breather system is clear, you may be getting crankcase pressure that is causing this.
Old Jun 22, 2010 | 12:12 PM
hxgaser's Avatar
For cam chain tensioner seal, use anaerobic sealant. Not silicone stuff...
hartsoe1
Apr 6, 2013 11:55 PM
fowvaydriver
Aug 1, 2011 10:46 PM
JcoyA6
May 20, 2008 12:53 AM
A6 Quattro V6 30V
Sep 19, 2007 11:57 PM
dubd012
Jan 12, 2007 03:53 PM
