B5 Valve Cover Mistake
Old Apr 6, 2013 | 11:37 AM
hartsoe1's Avatar
Default B5 Valve Cover Mistake
What it the purpose of the black plastic cover on the driver side cam under the valve cover. And, I only had one piece in there, which covers only half the cam. Also, on my atw, there is no rear breather hose. More German over engineering? Because, I left mine out by accident and I wonder if I need to take it back apart.
2000 1.8 atw
Old Apr 6, 2013 | 05:16 PM
AudiDeficitDisorder's Avatar
Pictures of some type would help alot
Old Apr 6, 2013 | 06:09 PM
hartsoe1's Avatar
Pics shouldn't be necessary - you've either seen them when doing a Valve Cover job or not. These plastic covers are the only movable thing under the V Cover that isn't screwed down.
But, I found a picture:
http://www.europarts4sale.com/servle...aver-VW/Detail
Old Apr 6, 2013 | 07:49 PM
bshusted's Avatar
The cover only goes over half of the cam because its purpose is to keep oil from being flung out of the filler hole if you remove the cap with the engine running.
Old Apr 6, 2013 | 10:48 PM
redline380's Avatar
Legal Moderator
Yeah the plastic cover doesn't do ****, just stops oil from slinging. Plenty of people including myself don't run them. As for no breather on your atw valve cover, that is normal. Aeb and atw pcv systems don't include a valve cover breather port, awm and newer do. You can run whatever you like, and there are many aeb/atw people that run a ported VC with a breather, but it's usually to a catch can
Old Apr 6, 2013 | 11:55 PM
hartsoe1's Avatar
Thanks to all. I ain't pulling it back apart. no matter what, with 192,000 miles, I'll take my chances. and it does seem to be over engineering to protect the stupid. Cheers.
saether
Apr 29, 2014 03:49 PM
jwd2a
Jun 22, 2010 12:12 PM
bluerivet
May 11, 2010 02:36 PM
tooxtreme8813
Sep 6, 2009 02:09 PM
