Need advice
Old Feb 2, 2019 | 05:07 PM
Shane Wentzel's Avatar
Default Need advice
So I picked up a Xtool VAG401 for my 2000 a6 Quattro, car was running fine before I hooked it up just wanted to check the codes. Had codes for O2 sensors so I cleared in case old they were old codes not cleared. Took the car out for a drive and went to go up a pretty steep hill and could barely make it up the hill, so hooked up again and I get a different fault I’ve never seen before and have never had a problem with until this incident. Any advice would be great putting a picture of fault. Ok so file didn’t load so trying this instead. Fault is charge pressure control positive deviation.
Old Feb 2, 2019 | 07:17 PM
kjopen's Avatar
is it a Turbo model? Sounds like you could have a boost problem, maybe a leak or a loose hose or something of that nature.... Post the code to us
Old Feb 3, 2019 | 12:08 AM
it is a turbo model
Old Feb 3, 2019 | 12:15 PM
kjopen's Avatar
Shane Wentzel
Feb 2, 2019 06:12 PM
cincinnatistuff
Dec 27, 2013 01:00 PM
a4ddt
Dec 31, 2005 05:19 PM
onepoint8tee
Nov 16, 2005 01:55 PM
