Need a decent Audi mechanic in Northeast PA/turn signal issue help.
Old Jun 28, 2008 | 01:23 PM
SingBlueSilver's Avatar
Default Need a decent Audi mechanic in Northeast PA/turn signal issue help.
Hi all...
I'm seeking a mechanic to fix an issue in my A6. All small specialty shops and even the only local dealership (the next closest one is in New Jersey) won't return my calls or aren't available to speak with when I call and get a receptionist. I have no turn signals! It's not a fuse, checked that. And the hazard lights work. So, I need some help. Anybody know of any shops that will actually return my calls, or... has anyone else had this problem and knows how to repair it and would be willing to give me some instruction?
All replies thoroughly appreciated...
Old Jun 28, 2008 | 01:39 PM
gottwinns's Avatar
Default RE: Need a decent Audi mechanic in Northeast PA/turn signal issue help.
alright man you turn signal relay has gone out, its a fairly easy fix so you should do it yourself, the part from audi is about $30
Turn signal relay
part NO: 4B0 941 509 D B98
link to diy:https://www.audiforums.com/m_146946/tm.htm
^^^^ also you dont need the tools he has just use a small flathead screw driver and be careful to not mess up the cover plate
you need anymore help, dont be afraid to ask me
Old Jun 29, 2008 | 03:50 AM
joetm's Avatar
gottwinns ... u from pa?
Old Jun 29, 2008 | 04:26 PM
gottwinns's Avatar
nah man im in tx but ive had this problem and helped a few people that had this problem before
Old Jul 1, 2008 | 11:29 AM
Cool. Ok, what do I do? Or, where can I find the information that tells me what I need to do? Is there a service manual that can help?
Old Jul 1, 2008 | 11:39 AM
Jeffla's Avatar
here is a write up, but the pictures are no longer there. I have a few on my home pc I can send you if you want. It is really straight forward.
Basically, pry off trim cover that surrounds hazard triangle on your dash, remove relay, put new one in, put trim back on.
http://forums.audiworld.com/allroad/msgs/91515.phtml
Killuminati
Apr 8, 2013 04:33 AM
donusty
Sep 24, 2012 08:46 PM
74bronco302
Jan 10, 2012 01:16 PM
krill74
Jan 21, 2011 12:27 AM
love the booB5
Aug 7, 2008 01:34 AM
