Need headlight help!
Old Oct 12, 2008 | 07:30 PM
plosbornjr's Avatar
Default Need headlight help!
I was trying to adjust my passenger side headlight. I was turning the adjustment screw when I heard a snap/crack. I did not turn it too tight, but the whole assembly seems to have slipped off and is now loose. The adjuster no longer moves the light. I found the stud/pin on the lower left hand side (looking at the back of the assembly from inside the hood). It appears that the assembly is supposed to fit on this and pivot from this point. I can't get it back on this pin, and my headlight is aimed way too low. I do not have HID's or auto leveling headlights. Any suggestions?
Old Oct 12, 2008 | 09:12 PM
Stampy's Avatar
You have to remove the headlight and pop it open. Its the only way you will be able to pop the ball joint back in. This is assuming the ball joint just popped out. I had the same thing happen to me and was very happy to find out it was just that.
You gotta be careful adjusting the headlights. If you are doing major adjusting, you are sometimes better off just loosening the light. Then you can move the whole assembly, rather than max out the adjustments and having pressure on joints.
Old Oct 13, 2008 | 08:21 AM
plosbornjr's Avatar
Thanks for your response. Looks like I'll be removing the headlight this weekend. Looks like some say you can't pull it out without removing the bumber, and some say you can. I'm going to try it without removing the bumber.
Old Oct 13, 2008 | 03:20 PM
Stampy's Avatar
I can have them out in 5 minutes. Just have to have the courage to flex that white tab that they sit into on the radiator support. I've done it like 6 times now and it hasn't broken yet.
Old Oct 18, 2008 | 02:34 PM
plosbornjr's Avatar
Well, I was able to do it with only minor difficulties! Kept dropping things, so I had to remove the belly pan. Only took me about 1 hour. These two writeups were a HUGE help!
http://forums.audiworld.com/a6/msgs/518246.phtml
http://www.rs6.com/forum/showthread....&threadid=3862
Old Oct 18, 2008 | 08:37 PM
Stampy's Avatar
Good to hear man. Was it just popped out, or was something broken?
Old Oct 19, 2008 | 10:14 AM
plosbornjr's Avatar
Nothing was broken. It just popped out.
Jrmiller
Feb 25, 2013 03:03 PM
Influentialstylez
Mar 29, 2007 04:30 AM
rkohan
Mar 20, 2007 04:16 AM
