Need help!!!
Old Dec 5, 2010 | 01:52 AM
tuned2.7A6's Avatar
Exclamation Need help!!!
Hey all-
I completed my cat removal with an electric cut-out installed finally (have had a few issues with it not closing all the way but seems to be working fine now). The shop that did it did a great job on also mounting the sensors into the new pipes so I would not get a check engine light... However, I had an oil leak fix done yesterday (did not do the chain tensioner yet) and an oil change along with it and everything was fine. But later in the day today my check engine light came on... Note, I have never had one before... Any ideas as to why this might be? Aside from calling the "german" specialist who did the fix for me on Monday, I would like to know if it could have caused some other issue. The car is running fine with no problems, I'm just a little worried.
I would also like to know if anyone has some info on where I could get a code reader that is dependable...
Thanks to any who have some advice!
I will re post to this if the light goes away tomorrow :/
Old Dec 5, 2010 | 08:55 AM
bob martin's Avatar
Get a VAG-COM reader for your laptop, then read the codes. The cheap ebay cables work fine. Your code could be anything.
Old Dec 5, 2010 | 11:12 AM
bigdadi's Avatar
If you don't have a laptop this is cheap and handy ...
Roadi RDT45 in Amazon.com $49.99
English interface, easy to-use, highly reliable and accurate tool, easy to-read LCD display, unit fits conveniently in the palm or your hand
Erases trouble codes and determines the malfunction indicator lamp (MIL) status, supports VW CAN BUS protocol
Reads trouble codes for four main systems, engine, transmission, airbag, ABS
Diagnostic code scanner easily retrieves trouble codes from your vehicle's computer to diagnose problems
Mini 8 X 2 LCD easy-to-read back lit LCD display, compatable with all Audi's sold worldwide, 1990 or newer models
Old Dec 5, 2010 | 11:50 AM
chefro's Avatar
.... compatable with all Audi's sold worldwide, 1990 or newer models.
Do they really sell it with the adaptor for < 1996 models?
The seller mispelled "compatible" in the description. I would definitely trust them
Old Dec 5, 2010 | 12:28 PM
bigdadi's Avatar
There are a few more models ... check it out in Roadi's home page
http://www.roadico.com/
