need help with codes
Address 03: ABS Brakes
Controller: 8E0 614 111 R
Component: ABS/ASR 5.3 FRONT D12
Coding: 00064
Shop #: WSC 02315
1 Fault Found:
00647 - ABS-TICS / Engine: Electrical Connection 2
35-00 - -
Address 08: Auto HVAC
Controller: 4B0 820 043 G
Component: A6-Klimavoll
Note: Excessive Comm Errors
thanx!
Coding: 00064
Shop #: WSC 02315
1 Fault Found:
35-00 - -
thanx!
Excessive Comm Errors regarding the heating/ac system..hmmm
what exactly is 00647 - ABS-TICS? Could you have a braking issue...have you tested the ABS system and checked the sensors.
Sorry I'm not able to help, I don't own a VAG-COM or this series Audi but I'm sure someone here can help diagnose those codes.
Coding: 00064
Shop #: WSC 02315
1 Fault Found:
35-00 - -
well,the lights for the ware of the brakepads and the ASR was on all the time when the engine was on.. There was a open connector,so the ASR did not work. so now when the connector is connected,both lights are gone and the ASR works again.
the problem with this code,is that it's not listed in the wiki where most of the codes are listed,so i had to find the problem my self.
Coding: 00064
Shop #: WSC 02315
1 Fault Found:
35-00 - -
