Need help please!! Windows, sunroof, inner lights don't work!! Whats the problem???
Old Sep 8, 2015 | 01:49 PM
  #21
eduyan's Avatar
Smile
Originally Posted by padog
The box under the driver seat is the interior control module your best bet is to find a used one just be sure the part numbers match. there can be two causes for your water problem you will want to pull your battery out and check the drain underneath it this was the cause of my flooding or it could be the sun roof drain which I have never had an issue with but do some searching here on the forums you will find many topics about it. Also be sure to inspect the wiring harness under the drivers seat and along the driver door sill there are butt connectors in the harness that corrode due to the water and will give you fits!
Followed your advice, all worked. Thanks.
EKGCC
Aug 9, 2021 12:03 AM
StevieP
Dec 22, 2014 08:45 AM
joelw0514
Feb 19, 2014 02:33 PM
philmeister
Jul 26, 2009 01:02 PM
yellowbmw
Nov 6, 2008 08:20 AM
