Need your help guys.
Old Jul 31, 2017 | 04:11 PM
Jenssy's Avatar
Default Need your help guys.
I have a 05 a6 quattro 3.2 that I initially thought the battery was drained because I left the headlights on auto. Car cranks and starts up on first try but dies immediately. After that if I keep trying just cranks.
Come back an hour later same thing. Starts up and shuts off immediately. I checked the 20a fuse on passenger side and it's good. I'm not sure where the fuel pump relay is? Any help is greatly appreciated. Thanks
Old Jul 31, 2017 | 06:37 PM
Jenssy's Avatar
Monday,31,July,2017,18:11:54:60261
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.1.3.0 (x64)
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: WAUDG74F65N108053 License Plate: JENSSY
Mileage: 257590km-160059mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 72 77
VIN: WAUDG74F65N108053 Mileage: 257590km-160059miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Cannot be reached 1100
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Cannot be reached 1100
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F1 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0050
Revision: --H15--- Serial number:
Coding: 01050106190F0120
Shop #: WSC 02325 785 00200
VCID: 2A5BD34D85144C1197-807E
2 Faults Found:
18082 - Powertrain Data Bus
P1674 - 008 - Implausible Message from Instrument Cluster
Freeze Frame:
Fault Status: 01011000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 17:08:51
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 33.0�C
Engine Off
Voltage: 11.73 V
Speed: 0.0 km/h
18347 - Powertrain Databus
P1939 - 009 - Missing Message from Controller for Access & Start Auth.
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 40
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 17:08:51
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 H HW: 09L 927 156
Component: AG6 09L 3.2 FSI USA 0020
Revision: --H01--- Serial number: 0050235
Coding: 0001002
Shop #: WSC 02335 785 00200
VCID: 29592C41801247099E-807C
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
Shop #: WSC 02331 785 00200
VCID: 2D51D851B4FA5B2972-8078
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 198
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 17:03:57
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0025
Hex Value: 0x018B
Hex Value: 0x00FF
Address 05: Acc/Start Auth.
Cannot be reached
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 730 E HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 360CH057521274
Coding: 0000003
Shop #: WSC 12345 111 45725
VCID: 23453E69E23E9D59D4-8076
Subsystem 1 - Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H07 0010
Subsystem 2 - Serial number: 00000000118468
Subsystem 3 - Serial number: 0102.03.050000000100010313�
Subsystem 4 - Serial number: 010313�
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 198
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:26:09
Freeze Frame:
Bin. Bits: 10
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0150
Revision: 00000026 Serial number: 00000000123049
Coding: 0524326
VCID: 5BB546899ACEE599DC-800E
2 Faults Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 158
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:16:07
Freeze Frame:
Bin. Bits: 00001000
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 158
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:16:07
Freeze Frame:
Bin. Bits: 00001000
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0013123
VCID: 66C3677D518CA87173-8032
Subsystem 1 - Component: Fehler Lin-Slave 01
Subsystem 2 - Component: Fehler Lin-Slave 02
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 158
Mileage: 257596 km
Time Indication: 0
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7129818
Shop #: WSC 00000 000 00000
VCID: 1B350689DA4EA5991C-804E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0310
Revision: 10H29000 Serial number: 00359D089ZZV
Coding: 0013622
Shop #: WSC 08315 444 55870
VCID: 2643277D910C6871B3-8072
Subsystem 1 - Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Subsystem 2 - Serial number: 6332CSME08324E6A8
Subsystem 3 - Serial number: 6342CSME09091473
Subsystem 4 - Serial number: 6351HSME065F0E4EP
Subsystem 5 - Serial number: 6361HSME06530071X
Subsystem 6 - Serial number: 6371VSME064A597C-
Subsystem 7 - Serial number: 6381VSME064B4C23Q
1 Fault Found:
000 - -
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenks�ulenmodul H07 0230
Revision: 00H07000 Serial number: 90025050570161
Coding: 0002021
Shop #: WSC 02323 785 00200
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 158
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:16:05
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H10 0610
Revision: 00500000 Serial number: 4R870Z235
Coding: 0067263
VCID: 1E330F9DC95CB0B1FB-804A
2 Faults Found:
00771 - Fuel Level Sensor (G)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 198
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:29:29
00438 - Fuel Supply Sensor 2 (G169)
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 198
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:29:29
Address 19: CAN Gateway Labels: 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 1200805221024C
Coding: 6CFE73C41B3104
Shop #: WSC 02054 002 1048576
VCID: 275D2A799606717988-8072
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 158
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:16:06
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 158
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:16:06
Address 37: Navigation Labels: None
VCID: 55A150B1BCEA33E9EA-FFFE
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H15 0100
Revision: 01000015 Serial number: 01003013850000
Coding: 0423997
VCID: 2C57D5558FE0522165-8078
Subsystem 1 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H02 1301
10 Faults Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 158
Mileage: 146704 km
Time Indication: 0
Date: 2010.07.17
Time: 13:56:45
01519 - Bulb for Back-Up Lights; Right (M17)
Freeze Frame:
Fault Priority: 3
Reset counter: 158
Mileage: 257484 km
Time Indication: 0
Date: 2017.07.18
Time: 11:10:48
02198 - Bulb for Tail Light 2; Left (M49)
Freeze Frame:
Fault Priority: 3
Reset counter: 158
Mileage: 257484 km
Time Indication: 0
Date: 2017.07.18
Time: 11:10:48
02735 - Bulb for Tail Light 3; Right
Freeze Frame:
Fault Priority: 3
Reset counter: 158
Mileage: 253601 km
Time Indication: 0
Date: 2005.01.12
Time: 02:17:55
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 158
Mileage: 253601 km
Time Indication: 0
Date: 2005.01.12
Time: 02:17:55
000 - -
Freeze Frame:
Fault Priority: 2
Reset counter: 158
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 10:23:17
01506 - Bulb for Rear Fog; Right (L47)
Freeze Frame:
Fault Priority: 2
Reset counter: 158
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 10:23:17
02734 - Bulb for Tail Light 3; Left
Freeze Frame:
Fault Priority: 3
Reset counter: 158
Mileage: 256266 km
Time Indication: 0
Date: 2017.01.13
Time: 12:25:06
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 3
Reset counter: 158
Mileage: 256266 km
Time Indication: 0
Date: 2017.01.13
Time: 12:25:06
01502 - Bulb for Rear Fog; Left (L46)
Freeze Frame:
Fault Priority: 3
Reset counter: 158
Mileage: 256442 km
Time Indication: 0
Date: 2017.01.24
Time: 13:28:03
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000073104
Coding: 0001114
VCID: 5EB34F9D89DCF0B1BB-800A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 158
Mileage: 257596 km
Time Indication: 0
Date: 2063.15.31
Time: 16:00:00
Freeze Frame:
Voltage: 11.500 V
Temperature: 43.0�C
Address 52: Door Elect, Pass.
Cannot be reached
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0005022
Shop #: WSC 02334 785 00200
VCID: 5DB1489184DAEBA9A2-8008
2 Faults Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 4
Fault Frequency: 54
Reset counter: 158
Mileage: 257592 km
Time Indication: 0
Date: 2017.07.31
Time: 04:40:40
Freeze Frame:
Voltage: 10.97 V
Count: 247
00576 - Terminal 15
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 4
Fault Frequency: 60
Reset counter: 158
Mileage: 257592 km
Time Indication: 0
Date: 2017.07.31
Time: 04:40:40
Freeze Frame:
Voltage: 10.97 V
Count: 41
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH05 0010
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 17
Reset counter: 158
Mileage: 257592 km
Time Indication: 0
Date: 2017.07.31
Time: 16:17:41
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0490
Revision: 00000000 Serial number: 00000000029763
Shop #: WSC 30592 001 1048576
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 1234567890
Coding: 344630393135313035432056413031323334353637383930
5 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 158
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:17:41
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 158
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:17:41
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:29:43
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 16:29:43
02277 - Quiescent Current Stage 6
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 257597 km
Time Indication: 0
Date: 2017.07.31
Time: 17:10:28
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 04:19)--------------------------
jiggleo
Jan 11, 2010 01:19 AM
zwhid
Oct 25, 2008 09:19 AM
kloepfer_3
Aug 8, 2008 01:15 AM
5000tq
Jun 1, 2008 04:42 PM
RomeA4
Jul 6, 2005 10:12 PM
