new owner, 3 codes
Hi fellow A6 owners. I'm a new, and proud owner https://www.audiforums.com/forum/new...estige-225275/
using odb2 scanner and the carista app (pro paid 1 week free trial)
Its giving 3 codes
ABS 00604 potentiometer (G113) in positioning motor for air flow flap (V71)
sound system 03278 function-limitation because of lacking info
body/convenience system 03637 control module electronics sunroof, function limitation because of high temperature
This is the first place I'm posting...i searched the forum for these codes and the 00604 had some, but most were really old on different cars. There were no results on the other 2.
Thanks
Its giving 3 codes
Thanks
using odb2 scanner BAFX Products 34t5 Bluetooth OBDII Scan Tool for Android Devices
Its giving 3 codes
Thanks
Its giving 3 codes
Thanks
Here is the quick report http://www.screencast.com/t/SYer1DpZ
Hereis the detailed report
ECU info obtained with Carista 3.4.5 for Android:
VIN:
CAN network gateway
Part #: 4G0907468AB
Coding: 00C1033000 (hex)
Component: J533--Gateway
[No fault codes]
Engine
Part #: 4G0907551A
Coding: 0A2A0034056600060000 (hex)
Component: 3.0l V6 TFSI
Fault codes:
13272 Manufacturer-specific code
Engine (2)
[failed to connect]
Engine (3)
[failed to connect]
Transmission
Part #: 4G0927158P
Coding: 000002 (hex)
Component: 0BK 30TFSIUSA
[No fault codes]
ABS
Part #: 4G0907379J
Coding: 44A70F0122E5F0804B00 (hex)
Component: ESP PREMIUM
Fault codes:
00604 Potentiometer (G113) in Positioning Motor for Air Flow Flap (V71)
Brake booster
[failed to connect]
Parking brake
Part #: 4H0907801E
Coding: [none]
Component: EPB-4
[No fault codes]
Power steering
Part #: 4G0909144L
Coding: 101000010000 (hex)
Component: RCEPS
[No fault codes]
Steering angle
[failed to connect]
Active steering
[failed to connect]
Steering wheel
Part #: 4H0953568H
Coding: 00043C (hex)
Component: Lenks.Modul
[No fault codes]
Airbags
Part #: 4G0959655A
Coding: 303234373131303030324A55304C34473053 (hex)
Component: Airbag10.43
[No fault codes]
Instrument cluster
Part #: 4G8920983
Coding: 0BC609040F01D705020000 (hex)
Component: TBenUsaAccNv
[No fault codes]
Infotainment display
[failed to connect]
Infotainment display (front)
[failed to connect]
Infotainment display (rear)
[failed to connect]
Infotainment display (rear left)
[failed to connect]
Infotainment display (rear right)
[failed to connect]
Infotainment display (roof)
[failed to connect]
Navigation
[failed to connect]
Voice control
[failed to connect]
Radio
Part #: 4G0035082C
Coding: 020007010000000001 (hex)
Component: Radio U SIRIU
[No fault codes]
Digital radio
[failed to connect]
Satellite radio
[failed to connect]
Sound system
Part #: 4G0035465A
Coding: [none]
Component: BO G3 C7
Fault codes:
03278 Function-Limitation because of lacking info
Media player
[failed to connect]
Media player
[failed to connect]
Media player
[failed to connect]
Media player
[failed to connect]
TV tuner
[failed to connect]
Digital TV tuner
[failed to connect]
Infotainment system
Part #: 4G0035746C
Coding: 050200000003EDEF75168B1E00000003100001000000000000 (hex)
Component: H-BNT-NA
[No fault codes]
Infotainment system 2
[failed to connect]
Telephone
[failed to connect]
Immobilizer
[failed to connect]
Towaway protection
[failed to connect]
Headlight aiming
Part #: 4H0907357A
Coding: 1221A6601002A400 (hex)
Component: ....LWR12....
[No fault codes]
Left headlight
[failed to connect]
Right headlight
[failed to connect]
Tire pressure monitor
[failed to connect]
[failed to connect]
Heater & air conditioning
Part #: 4G0820043L
Coding: 668120BA5C (hex)
Component: KLIMA 4 ZONEN
[No fault codes]
Rear heater & A/C
Part #: 4G0919158D
Coding: 00 (hex)
Component: KLIMA FOND
[No fault codes]
Auxiliary heater
[failed to connect]
Auxiliary heater
[failed to connect]
Parking sensors
[failed to connect]
Parking/steering assist
Part #: 4H0919475Q
Coding: 280906 (hex)
Component: PARKHILFE ACC
[No fault codes]
Auto-leveling suspension
[failed to connect]
All-wheel-drive system
[failed to connect]
Differential lock
[failed to connect]
Chassis
[failed to connect]
[failed to connect]
Central electronics
Part #: 4H0907063BP
Coding: 09072091073C9FE281000884A0003800CF9CD308A208012580 01085C3B00 (hex)
Component: BCM1 2.0
[No fault codes]
Central electronics 2
[failed to connect]
Body/convenience system
Part #: 4H0907064BR
Coding: 0106023A00FA448580B0088002050000000000000000000000 0000000000 (hex)
Component: BCM2 2.0
Fault codes:
03637 Control Module Electronics Sunroof, funktion-limitation because of high temperature
[failed to connect]
Driver's door
Part #: 4G8959793D
Coding: 011F17205E00628002000013 (hex)
Component: TSG FA
[No fault codes]
Front passenger's door
Part #: 4G8959792E
Coding: 011F17205E00628002000002 (hex)
Component: TSG BF
[No fault codes]
Rear left door
Part #: 4G8959795E
Coding: 010F17204000628002000002 (hex)
Component: TSG HL
[No fault codes]
Rear right door
Part #: 4G8959795E
Component: TSG HR
[No fault codes]
Trunk
[failed to connect]
Driver's seat
Part #: 4G8959760A
Coding: C0581B008F002001000001010101102030303232203232 (hex)
Component: MEM-FS
[No fault codes]
Front passenger's seat
[failed to connect]
Rear seat
[failed to connect]
Rear seat (driver's side)
[failed to connect]
Entry assist (driver)
[failed to connect]
Entry assist (passenger)
[failed to connect]
Ignition authorization
Part #: 4H0907064BR
Coding: 0D882006000000000000 (hex)
Component: BCM2 2.0
[No fault codes]
Battery regulator
[failed to connect]
Battery charging
[failed to connect]
Convertible top
[failed to connect]
Roof electronics
[failed to connect]
Windshield wipers
[failed to connect]
Trailer
[failed to connect]
Adaptive cruise control
Part #: 4G0907561A
Coding: 3601010202 (hex)
Component: ACC3
Fault codes:
10496 Manufacturer-specific code
Lane-change system
Part #: 4G0907566D
Coding: 1 (decimal)
Component: J769 SWA Master
[No fault codes]
Lane-maintain system
[failed to connect]
Position sensing
[failed to connect]
Back-up camera
Part #: 4G0907441B
Coding: 1080004 (decimal)
Component: SG Rueckfahrkame
[No fault codes]
Telematics
[failed to connect]
Driver ID
[failed to connect]
Intercom
[failed to connect]
Additional functions
[failed to connect]
Operations
[failed to connect]
Hybrid engine
[failed to connect]
Back-up camera
[failed to connect]
Image processing
Part #: 4G0907107D
Coding: 048198180111 (hex)
Component: BV-SG
[No fault codes]
Sliding door (left)
[failed to connect]
Sliding door (right)
[failed to connect]
Thermal Management
[failed to connect]
Structure-borne sound
[failed to connect]
External noise actuator
[failed to connect]
Driver assist front sensor
[failed to connect]
Rear axle steering
[failed to connect]
Rear axle steering 2
[failed to connect]
Steering column lock
[failed to connect]
Special vehicle assist
[failed to connect]
Sensor electronics
Part #: 4G0907637B
Coding: [none]
Component: SARA 6D
[No fault codes]
A/C compressor
[failed to connect]
3rd row seats
[failed to connect]
Gear selector switch
[failed to connect]
Heads-up display
Part #: 4G0919604G
Coding: D20000 (hex)
Component: HeadUpDisplay
[No fault codes]
Night view
Part #: 4H0907547E
Coding: 1311 (hex)
Component: NV-ECU-Gen1
[No fault codes]
Onboard Camera
Part #: 4G0907217A
Coding: 6A060000 (hex)
Component: DPC-SG
[No fault codes]
Multicontour seat (driver)
[failed to connect]
Multicontour seat (passenger)
[failed to connect]
Multicontour rear seat (driver's side)
[failed to connect]
Multicontour rear seat (passenger's side)
[failed to connect]
Adaptive cruise control 2
Part #: 4G0907541A
Component: ACC3
[No fault codes]
Hybrid battery
[failed to connect]
Seatbelt pretension (front left)
Part #: 4H0980945B
Coding: 0066E608031F037E070308014240C2010000 (hex)
Component: RGS-VL
[No fault codes]
Seatbelt pretension (front right)
Part #: 4H0980946B
Component: RGS-VR
[No fault codes]
Microphone
[failed to connect]
Infotainment interface
[failed to connect]
Reductant control
[failed to connect]
Brake sensors
[failed to connect]
Roof electronics 2
[failed to connect]
Auxiliary display
[failed to connect]
Motor mounts
[failed to connect]
Rear driver's door
[failed to connect]
Rear passenger's door
[failed to connect]
Sliding door (rear, left)
[failed to connect]
Sliding door (rear, right)
[failed to connect]
Battery charging
[failed to connect]
High-volt battery charging
[failed to connect]
Transmission 2
[failed to connect]
DC/DC converter
[failed to connect]
Pedestrian protection
[failed to connect]
Sunroof
[failed to connect]
Lane-change system 2
[failed to connect]
Front axle lift
[failed to connect]
Roll control 1
[failed to connect]
Roll control 2
[failed to connect]
Light control 2 (left)
[failed to connect]
Light control 2 (right)
[failed to connect]
LED headlight power (left)
[failed to connect]
LED headlight power (right)
[failed to connect]
Rear spoiler
[failed to connect]
CasopoliS
May 22, 2011 12:15 PM
