New PCV system. Still losing oil...
hey Bob so with the cooling issue I kinda got sidetracked with this issue but here is an update. I went poking around for the oil leak and in my poking around I found out that its not engine oil at all. its turns out that its gear oil from the passenger side axle flange just what I needed to find out ugh...is that a hard fix?
The more I think about the more I'm not sure what's leaking gear oil. When you pull an axle no gear oil leaks so it must be a seal in past the axle that is bad. Still going to need the triple square to pull the axle. It's not too hard. Might have to drop the suspension from the pinch bolt to get it out. Search the forums for a pictoral procedure.
Not if it's just loose. You will need a triple square wrench to get the bolts out and back in. Not sure what size, I think it's a cr-v10, but they come in sets of 4. Get the long ones. Pull the wheel and reach in there and check for loose ones. Can't remember if there is a gasket or 'O' ring. Might just be black RTV.
