Newbie w/ Motor n Tranny Probs '99 A6 Quattro
Old Feb 15, 2011 | 08:11 PM
kray4439's Avatar
Default Newbie w/ Motor n Tranny Probs '99 A6 Quattro
I need HELP!! Bought the car w/ bad tranny. Bought a '98 quattro for good tranny. had a back yard shop replace. Now the tranny slipping n motor skipping. Not sure now if tranny codes matched?? Dnt have access to '98 parts car any longer. Guess first thing is check fluid level right? As for motor... idles (barely) but very low rpm. Press on accel. it sputters but climbs all the way thru. Have check engine light on but havent scanned yet. Hopefully tomorrow can get that done. Plz any help or suggestions would be greatly appreciated. Also.... have 98 vin# if that can be decoded for tranny code??not sure.
Old Feb 18, 2011 | 03:26 PM
kray4439's Avatar
Default Update....
I have a gang of codes. Scanned with generic scanner...
P1545
P0301
,P1237-1242
P0722
P1426 had intake box undone with maf still connected
P1432
Anyone have any suggestions where to start? Started with new plugs because they were shot. What next?
Old Feb 18, 2011 | 07:38 PM
chefro's Avatar
P1545
P0301
,P1237-1242
P0722
P1432
P0301 - it could be Cylinder 1's coil, or bad spark plug - that's a misfire code
P0722 - it may be related to a Transmission Range sensor circuit - you can check if all the power connectors on the tranny are plugged properly
P1237-1242 - All the injectors "Open Circuits"
P1426 Tank Ventilation Valve - Open Circuit A
P1432- It may have something to do with the secondary air injection valve
It sounds like you have a whole range of ELECTRICAL problems.
Did they connect properly all the grounds?
Old Feb 18, 2011 | 07:47 PM
kray4439's Avatar
Not sure. Any idea how many our locations
kray4439's Avatar
Not sure. Any idea how many or locationsof them ?
The6
May 10, 2007 10:01 PM
18ToHATE
May 31, 2006 10:35 PM
Jim Clark
Feb 5, 2006 06:10 PM
A4life
Nov 13, 2005 05:31 AM
Flip_x
Nov 10, 2005 11:23 PM
