no power to fuel pump
I would go to the relay and make sure it has voltage where needed (I bet not). Then, you have to go upstream to find out what items affect the turning on of the fuel pump relay, such as the ignition switch or relay.
If the relay is being powered and is working (hove to check both, then test continuity from the relay socket to the fuel pump connector.
Bob
Bob
