O2 sensor replacement procedure?
Old Aug 7, 2007 | 09:27 AM
bolsen's Avatar
Default O2 sensor replacement procedure?
I own a 2002 A6 Quattro 3.0. The check engine light is on, with OBDII code P0050 "HO2S Bank 2, sensor 1". I believe this is the O2 sensor upstream from the cat, on the driver's side. From the engine bay, I can see the sensor, but a lot of stuff is in the way, including the brake fluid reservoir. Can someone please advise me on a replacement procedure for this item? Specifically, should I approach the sensor from above (via the engine bay), of from below (under the car)? Any additional "gotchas" involved in the replacement?
Thanks. Brian
AudiPhobic
Aug 17, 2011 09:32 AM
chromatin
Dec 21, 2010 03:24 PM
Joe Mazza
Dec 13, 2010 12:56 PM
bolsen
Mar 14, 2008 02:24 PM
blackA4
Jan 30, 2006 03:12 PM
