oil pan leak
Old Oct 21, 2006 | 09:36 PM
a6thunder's Avatar
Default oil pan leak
can anyone help on where i can get some help or instructions on removing the oil pan and where you would recommend a place that sells a new gasket for an audi a6 2001 4.2l quattro so i can replace it, leak is bad, can anyone help? i'd appreciate it.
Old Oct 23, 2006 | 02:49 PM
a6thunder's Avatar
Default RE: oil pan leak
or does anyone have an idea on how to fix the oil leak or can direct me to a forum or link for assistance? i'd appreciate it. thanks
a6thunder's Avatar
Old Oct 26, 2006 | 02:17 AM
dankhound's Avatar
The pan is easy. Its right on the bottom of the engine and theres like ten bolts holding it on. As for the gasket it shouldnt be all that expensive at a dealer.
Old Oct 26, 2006 | 02:44 AM
AUDIA8's Avatar
First double check that it is indeed the oil pan. I havent seen very many pans leak on the 4.2. I have a A8 with an oil leak I originally Thought was the oil cooler on the passenger side. But after further investigation I found the oil coming from the front right corner of the head gasket.
Double check before you starting taking it apart!
Old Oct 27, 2006 | 08:19 PM
a6thunder's Avatar
thanks for the info, i will look again to see where the leak is coming from, i called a few places to ask about the oil pan gasket but there is no part for it. so i am assuming its something else, i will look into it and post later what was found
Old Oct 29, 2006 | 03:10 PM
dankhound's Avatar
If theres no part then itll use the silcone sealant as a gasket.
Octane567
Aug 8, 2014 10:28 AM
vtraudt
Feb 25, 2012 11:09 AM
mikeeboy82
Jun 13, 2009 11:09 PM
inventorA6
Apr 15, 2009 06:46 AM
