oil sensor problem?
Old Dec 28, 2006 | 05:17 PM
gwilson's Avatar
Default oil sensor problem?
Hi, new to forum...'02 a6 avant 3.0 has yellow oil sensor light on and oil temp gauge is at zero. could these be related? does sensor light go on if gauge is malfunctioning?...which sensor sends oil temp info to gauge?
Old Dec 28, 2006 | 05:33 PM
gwilson's Avatar
Default RE: oil sensor problem?
...and, what is ECS? parts store?
Old Dec 29, 2006 | 03:23 AM
dankhound's Avatar
Both readings come from the oil level sensor on the bottom of the oil pan. Check the wiring at the sensor. If everything visually checks out, replace the sensor. Also use the dipstick. Make sure you actually have oil before you run the car any more.
Old Dec 29, 2006 | 12:42 PM
gwilson's Avatar
thanks, Dank! (and thought that was the problem, but now not so sure...I learn that the oil sensor from ecs does not send temp according to them: "Yes it does fit, the 3.0 is the same motor in the avant, and the sedan. It does not send temperature to the gauge, it is a oil level sensor only." Is ECS wrong here, or are we?
Old Dec 29, 2006 | 05:17 PM
gwilson's Avatar
found the part...THANKS ALL...Sender, Oil Temperature ES#4833...from ecs tuning...14 bucks,...I'm told there are two and located on a pipe close to cylinders on each side of engine
Old Dec 30, 2006 | 12:32 AM
dankhound's Avatar
They always gotta go changin stuff on me. There is indeed a seperate sensor for temp. It appears to be in the area of the crank pull on the drivers side of the engine.
Nuglets
Aug 2, 2010 04:00 PM
tkrick
Apr 29, 2009 11:12 PM
ins516a4
Dec 7, 2007 05:32 PM
Jocke112
Oct 13, 2007 08:21 AM
toyolla86
Oct 29, 2006 12:23 AM
