Ok now confused
Old Feb 22, 2006 | 09:35 PM
JG's Avatar
JG
Default Ok now confused
So the car is stalling and losing revs and then the oil warning lamp (the serious one) starts flashing.
Options are 1
dead engine (terminal at least)
Option 2
something else
Have checked oil pressure with mechanical gauge - Stable 4.0 bar falling to 3.5 bar when hot. So presumably not a major mechanical.
which leaves Option 2
Installed new pressure switch but symptoms remain the same with addition that rev counter is also now dead..
Wiring seems OK.
Am nervous of driving despite apparently good oil pressure - worried that some electrical aspect will kill engine (probably while passing a truck).
Any ideas anyone?
Old Feb 28, 2006 | 02:26 AM
dankhound's Avatar
Default RE: Ok now confused
Just for the hell of it try unplugging the abs controll module.
Old Feb 28, 2006 | 02:30 AM
dankhound's Avatar
Ok so maybe i should give you a little more than that. Saw the same problem on a vw passat today. The vehicle was diagnosed with a faulty abs control module. Common problem on both vehicles. Figured there was a problem with the can data bus and since the abs control module was know to be faulty that seemed like a good place to start. Definatly sounds like a data bus problem however as the rpm signal comes from the ecm.
drobrt
Feb 3, 2010 09:45 PM
chongboi
Nov 21, 2009 06:02 PM
audi freak
Dec 28, 2006 01:09 AM
yohan
Dec 22, 2006 03:29 PM
