Overheating warning?
Old Feb 6, 2007 | 01:15 AM
Dane27's Avatar
Default Overheating warning?
Ok, I've got a really strange problem...thought you guys might be able to help out a little bit.
I've got a '96 Audi A6, and I absolutely love it. However, it's had some problems. I've recently had to have the head gaskets replaced. I mention this only because before I did, I was getting overheating warnings, so now that I'm getting a similar warning, I thought it might be pertinent.
Anyway, when I first start my car up in the mornings, the overheating alert goes off...it stays on for about 5 minutes, then turns off, and doesn't turn back on, except occasionally when I do a hard corner. The temperature gauge never goes over what I've been taught is the "acceptable" temperature, and the oil temperature doesn't even get close. Both of them hit the red pretty hard when my head gaskets needed to be replaced.
I'm in Utah, and it's been FREEZING. I've had a hard time believing that my car could be overheating 20 seconds after starting it up, and no longer overheating once it was warm.
In addition, I think I need powersteering fluid...not sure if that's at all related, but couldn't hurt to mention it.
Hope you guys have some idea what might be the problem.
Old Feb 6, 2007 | 02:30 AM
vibroman's Avatar
Default RE: Overheating warning?
sounds like the temp sender unit has gone awol and sending the wrong signal to the ecu.
Old Feb 6, 2007 | 03:34 PM
2k S4's Avatar
Besides the sensor, is there enough coolant in the system? Are you sure there are no air bubbles?
Check the sensor first.
There is no way you can can be that hot when first turned on in the morning.
srlito
Apr 22, 2013 02:54 PM
Clrwatrtom
Feb 2, 2013 07:01 PM
dauna50
Jul 25, 2011 06:50 AM
myslow1
Apr 18, 2009 09:35 PM
grim2.8
Jul 25, 2006 02:53 AM
