P0321 code
Old May 11, 2009 | 11:50 PM
pstyle's Avatar
Default P0321 code
I have the P0321 code on my 2000 A6 4.2 ran fine but i couldent clear the code. So i replaced the crank sensor and the engine light clears but i still have the same code. Any suggestions.
Thanks paul
Old May 12, 2009 | 12:10 AM
auditech79's Avatar
P0321
Ign./Distributor Eng.Speed Inp.Circ Range/Performance
Does the engine run any differently with the code still there? Is it hard to start?
I would look at the harness connector for the crank sensor for any corrosion or stretching in the harness.
Old May 12, 2009 | 10:21 AM
pstyle's Avatar
before i put the new sensor in the rpms would move up and down but since i replaced it has smoothed out. The engine runs fine starts right up doesn't stall. The engine light came back on today same code P0321. Got me stumped since most the articles i read the car wont start or stalls with this code.
Old May 12, 2009 | 05:40 PM
auditech79's Avatar
Did you match up the part numbers on the crank sensors? I can't explain why it would give that fault code unless there is something wrong with the sensor/harness, or the ECM is having trouble computing the information. If the numbers match up you may have to take it to the stealership.
Old May 12, 2009 | 06:53 PM
pstyle's Avatar
ok thanks for your help
Old May 12, 2009 | 11:30 PM
Midniteoyl's Avatar
Could be a shim is needed, or needed to be removed. I've noticed that 'replacement' sensors dont have nearly as strong a magnet as the originals.
Old May 13, 2009 | 10:34 AM
pstyle's Avatar
I did put the shim back in ill try removing it and see what happens thanks for all your help
Old May 13, 2009 | 01:13 PM
Midniteoyl's Avatar
Just make sure it doesnt hit the reluctor wheel....
tdepirro
May 24, 2012 03:02 PM
CRISTINAA8
Oct 19, 2009 12:04 PM
CRISTINAA8
Aug 22, 2008 02:30 PM
CRISTINAA8
Aug 13, 2008 10:00 AM
thedon28
Jul 11, 2008 09:25 PM
