Sponsored by:
Sponsored by:
P1624 and P0411 Question?
Old 07-19-2007, 01:30 PM
binzer33's Avatar
Default P1624 and P0411 Question?
I have a 98 2.8 with 112k. CEL light came on and got the 18032 and 16795 codes. I think these are definetely related to the secondary air injector. Where I live I do not have to go through an emission tests for to pass inspection, is it possible to bypass the secondary air injector and to somehow make the CEL light go out? Can I remove the secondart air injector all together and not have to worry about it?
Old 07-19-2007, 02:12 PM
auditech79's Avatar
Default RE: P1624 and P0411 Question?
P0411 Secondary Air injection system incorrect flow detected.
P1624 isn't on my DTC chart, i don't recognize that fault code either.
As for the secondary air fault check your vaccum lines to your combi valve on the back of each cylinder head. Check plastic lines coming from the secondary air pump for cracks, if no problems replace the secondary air pump. You will fail emmisions with this fault code, you cannot by-pass the fault code.
Changing one thing will create a different fault code in its place.
dave t
07-21-2014 07:08 PM
smithd2424
07-09-2013 09:12 PM
DurrDurrington
11-11-2010 05:44 PM
1stA6
06-14-2010 07:46 PM
vikingfan
04-20-2008 05:23 PM
Quick Reply: P1624 and P0411 Question?
