Parking brake cable replacement required?
Old Jul 3, 2013 | 01:43 PM
blaqswan's Avatar
Default Parking brake cable replacement required?
Car: 2002 A6 3.0 Quattro automatic
When my g/f and I were R&R'ing the fuel tank in her car, we had a problem with the adjuster on the left parking brake cable.
I had disconnected the cable end and housing end from the caliper, so there was no tension on either the housing or the cable.
When I removed the left adjuster from its mount in the left control arm, the adjuster extended to what I guess is its maximum position.
I can not get it to go back together. All the write-ups I've seen about adjusting the parking brake cables say just to pull or push on the adjuster.
I push on it, I wiggle it back and forth, I move it round and round... it just doesn't go back together.
Is there a trick to getting the adjuster to go back together?
Do I need to buy a new parking brake cable just because the adjuster came apart? The clear plastic sheath on the cable is a little chewed up, but the cable isn't rusty or frayed, so it's still perfectly serviceable.
Thanks!
Attached Thumbnails Parking brake cable replacement required?-20130603_132133-1.jpg   Parking brake cable replacement required?-20130603_132142-1.jpg   Parking brake cable replacement required?-20130603_132209-1.jpg
Old Jul 5, 2013 | 11:12 PM
blaqswan's Avatar
Bump.
TheBeardedFury
Jan 3, 2013 03:13 PM
a2thy
Mar 6, 2012 09:08 PM
floresralph
Jun 27, 2011 08:44 PM
01a4bes
Jan 17, 2011 10:23 PM
T90
Nov 19, 2005 05:31 AM
