POWER STEERING PROBLEM???? Not fluid.
Old Dec 26, 2006 | 07:44 PM
rusted212's Avatar
Default POWER STEERING PROBLEM???? Not fluid.
I just got done replacing the Steering Rack in my A6, I have yet to get it to Audi for an alignment I don't get paid until Friday, but something weird has just happend it almost refuses to turn LEFT has anyone ever heard of this, any help would be GREATLY APPRECIATED?
Old Dec 26, 2006 | 08:15 PM
muscle750's Avatar
Default RE: POWER STEERING PROBLEM???? Not fluid.
How far have u drove it yrds or miles since the rack was done if yards i would say that on some cars you have a bolt that holds the rack centre when fitting and must be removed to enable rack to move, also what oil u put in it if u put ATF fliud in................UNLUCKY! Thats the red stuff, cos i seen one that has and the seals swell and blow, You must use the gen green snotty stuff that Audi sell for 3k a tin! If none of this rings home next jack it up and try moving the wheels by hand see what happens if thats ok then either stick a scaffolding pole throu the steering wheel or stick some flames under it. Seriously i would say if the oils ok the bolts out if its got one then disconnect the track rods and try it you might have a siezed ball joint but i doubt it Good luck!
Nice job doing the rack aint it...............................NOT!!!!!!
I just done one on a new A6 would help if Audi didnt put the bolt under the heater!!
snsamotors
Jan 5, 2010 09:06 AM
snsamotors
Jan 3, 2010 04:20 PM
bren
Oct 28, 2007 07:21 PM
thrax982
Mar 31, 2005 10:15 PM
