Power Window Regulator
Old Oct 25, 2007 | 12:46 PM
Tha Abbot's Avatar
Default Power Window Regulator
My driver side rear window regulator does not work like it should. It goes down find, the problem is when it comes up. I had it checked, basically around $500 (part and labor). Is the regulator difficult to install or will I have to take it somewhere to get it fixed?
Old Oct 25, 2007 | 06:42 PM
auditech79's Avatar
Default RE: Power Window Regulator
If you don't know what you're doing you will have a hell of a time lining up the window carrier back up to sit flush on the body, so you don't get wind leaks. I would have a shop do the regulator for you.
Old Oct 25, 2007 | 11:17 PM
dankhound's Avatar
Lining up thewindow carrieris a piece of cake. Just mark around the bolt holes with whiteout before you remove them. Then just reinstall them in the same place.As long as you install the shims in the place where they came from, everything will line up perfectly.
Old Oct 26, 2007 | 10:53 AM
Tha Abbot's Avatar
Ok, thanks, I'm gonna just take it somewhere, I'm not feeling that lining the windows business.
Old Oct 28, 2007 | 11:28 AM
dankhound's Avatar
I also remembered something else. The regulaor is rivited in place. So youll have to cut or drill out the old rivits and buy,borrow, steal a rivit gun to install the new rivits.
Old Oct 30, 2007 | 09:02 PM
mpw2.7T's Avatar
Are you sure it's the reguilator and not just the platic window guides? They are a common problem and an easy, cheap DIY job.
Old Oct 30, 2007 | 09:55 PM
auditech79's Avatar
ORIGINAL: mpw2.7T
The plastic guides are only for the front window regulators.
h4x0r
Dec 31, 2011 12:20 PM
Randall41
Oct 28, 2011 12:31 PM
Dkauffman@tampabay.rr.com
Feb 2, 2011 10:55 AM
Agro
Jun 20, 2006 05:26 PM
ericf52389
Oct 28, 2005 01:28 AM
