Problem - ABS Module Master
Old Nov 7, 2005 | 06:49 PM
techbod's Avatar
Default RE: Problem - ABS Module Master
im pleased for you mate, a cheap easy fix
Old Nov 7, 2005 | 06:54 PM
techbod's Avatar
fuse #10 and 13 are part of the system to protect other modules, #7 is the main one to the ABS pump
Old Nov 8, 2005 | 07:59 PM
karguy427's Avatar
ORIGINAL: gilee_8
??? Karguy, I replaced my ABS ECU module already. (sent into ModuleMaster) and get it fixed.
but it's still having that problem.
So..
Sorry.....Got all bolluxed up with the ABS......ECU....VAGCOM.....BEEP...BEEP......MODULE MASTER....UPS.......yada yada yada. Guess I need to READ better.
Old Nov 8, 2005 | 08:40 PM
techbod's Avatar
"He who makes no mistakes makes nothing" old proverb you were probably exorsted after a hard day at work thats the one I use
Old Nov 8, 2005 | 11:12 PM
gilee_8's Avatar
Agrees! lol. thanks for all the help guys!
I greatly appreciated!
Gil
Now all I have left is to figure out WHY my Transmission is shifting badly.
between shift from 3rd to 4th gear is the worst. it will neutral for a second with RPM shoots up for about 500RPM (depend on how much I stepped on the throttle) then when it engage in gear, either smoothly (coz I didn't stop too much into the throttle) or it will CHOKE BADLY (feel like a rear ended type feeling)
I need help on that guys!
No Check engine light, no faulty code at all.
What's up?
I am going to post a new post on this.
Gil
skypefreak
B7 Models
Sep 14, 2011 12:22 PM
SeaWolfxix
Jun 6, 2010 12:26 AM
definitivejohn
May 24, 2009 09:13 PM
