Problem with fog lights
Old Jan 11, 2007 | 05:05 AM
A6 Quattro V6 30V's Avatar
Member
Default Problem with fog lights
On my 99 A6Fog lights don't come on when I turn the turn swith orpull it out. Does anyone have any Ideas on what I can do?
Old Jan 11, 2007 | 11:49 AM
Boston Driver's Avatar
Default RE: Problem with fog lights
Check your fuse. Do you know thatyour lowbeams must be on for the foglights to work? That is the way it comes from the factory.
There are a couple of methods you can use to get those to work independently of the lowbeams, but neither is ideal. Here are the two taht i am familiar with:
1)Use right-angle fuse taps and jump to another fuse location. However, the only "vacant" fuse location that works is for the rear wiper, and doing this mod in the Avant will result in a loss of functionality for the rear wiper. Here is the link: http://forums.audiworld.com/a6/msgs/375675.phtml
2)A wire in the headlight switch harness iscut and spliced to another wire. However, this mod enables the foglights to be on ALL the time the **** is turned to the parking light position, and the foglights will ALWAYS be on even with the lowbeams. Here is the link: http://www.htms.org/fogmod.html
Old Jan 18, 2007 | 03:35 AM
Member
I tried checking the fuse but I dont know where it is or what color it is. I know where the fuse box is on the driver side but which one is the fuse?
Old Jan 18, 2007 | 09:26 AM
SouthboroAudiGuy's Avatar
There should be a guide to which fuse does what in your manual. Also, check the door to the fuse box -- there's usually a sticker there that also has a key to what/where.
Old Jan 18, 2007 | 09:47 AM
techbod's Avatar
[IMG]local://upfiles/12092/E4965474956E456A8EA347BDAFC9826E.jpg[/IMG]
Old Jan 18, 2007 | 03:31 PM
Jeffla's Avatar
Since having the headlight switch recall done, now I can turn my fogs on with only the parking lights on (no lowbeams).
Old Jan 30, 2007 | 01:56 PM
Member
my light dont come on at all when you turn the dial or pull it out, and that panel doesnt say wht control the fog lights. I need some help man. anyone.
MAB21
Nov 10, 2013 02:23 PM
cartronicshn
Audi Q7
Sep 13, 2013 09:29 AM
dhughton
Dec 2, 2011 09:56 PM
tims_S6
Jul 29, 2009 03:48 PM
