propeller shaft part #???
Old Nov 6, 2009 | 01:02 AM
jchaffee1's Avatar
Default propeller shaft part #???
i have a 2000 a6 2.8L quattro avant automatic
anyone know the exact part number of the propeller shaft?
i've had that marble in a paint can/ clicking noise going on for some time now...haven't done anything about it. mainly it's been just a sound annoyance, how sketchy is it to just leave it alone?
i've seen some pretty cheap props on ebay part # 8D0 521 101 D and H not sure if this fits my car.
Anyone know for sure?
Old Nov 6, 2009 | 08:58 AM
bob martin's Avatar
Old Nov 6, 2009 | 11:58 AM
jchaffee1's Avatar
hmmm...looked through that like 5 times can't find it. I see front drive axles and rear drive axles but no center drive??? am i just missing it somewhere?
Old Nov 6, 2009 | 12:33 PM
Lyman_T's Avatar
Well, there's this one, but it does still have the propeller attached. Works pretty good if you have a trailer hitch....
Old Nov 6, 2009 | 02:40 PM
catdog's Avatar
I had the same problem. Dealer wanted $1200. Bought at a junk yard for $160. Been over a year and running just fine. My front CV joint on the shaft was bad.
Old Nov 6, 2009 | 06:20 PM
jchaffee1's Avatar
even if i find one, seems like a pain in the *** job to do by yourself w/ only car jacks and ramps. did you install it yourself? if so did you use the alignment tool to keep the shaft from bending? i looks like you can buy the new cv joints for it...wonder if i can just replace that.
Old Nov 6, 2009 | 09:27 PM
catdog's Avatar
No, I had it done. Labor was $250. The mechanic took it off. I took it to the junk yard and matched it up and took it back to my mechanic. I think the dealer told me they only sold the entire shaft. 2 shafts really with the u joint in the center & the cv joints on either end as I recall. The replacment was a little different. I think the rear shaft was a little smaller diameter than the front shaft but the lenth was the same & the bolt holes lined up. I was pleased with the cost, $416 total.
Old Nov 9, 2009 | 07:20 PM
bob martin's Avatar
Hhhmmmm. My apologies. I thought I saw it in there but I guess not. Anyway, from VAGCAT:
4B0521106F
propeller shaft
/ 5-speed automatic: AKC,AFB,AKN, ATX,AGE,APR, AQD,AMX,ARN, ASM,APZ,AMM, APS,ARJ,AML, APC,AJK,ALG, ACK,APB,AJK, AZA,AGA,APC, ALF,AJG,ALW AKE
4B3521101E
propeller shaft
/ 5-speed automatic: ARS,AQJ,ANK, ASG
Does anyone know what these codes refer to?
Bob
waqar
Feb 3, 2013 03:50 AM
savantv
Jul 6, 2012 03:16 PM
NogaroFan
Mar 7, 2011 07:16 PM
