pulley noise
Old Mar 12, 2007 | 02:53 AM
wings7351's Avatar
Default pulley noise
One of the pulleys in my 99 2.8L is making noise when it's cold, then after a while the noise level would go down a little bit. But I am not sure how to diagnose which pulley is making that noise or does anyone know what my best bet on this would be?
Advice is appreciated.
Old Mar 12, 2007 | 03:49 PM
verdict's Avatar
Default RE: pulley noise
I have the same issue right now. I have opened another tread waiting for replies from other friends here. It is your Idler Pully i am assuming. If this is your experience.
you start the car early morning. Then at the front of the engine you would here the noise coming. which is little bit irritating also. Then once you are inside and engine is running for a while, the noise is down but not completely gone.
Then i think it is the idler pully.
Old Mar 12, 2007 | 09:32 PM
wings7351's Avatar
Verdict, did you mean the idler pully on timing belt? Thanks.
Old Mar 13, 2007 | 02:49 AM
Vaudi's Avatar
You can spray the serpentine belt with some lube to make sure its not coming from the serpenitne belt or one of its pulleys
Old Mar 13, 2007 | 04:36 AM
auditech79's Avatar
Yeah just don't spray water on it because it tends to have the opposite effect.
AlyAudi03
Oct 13, 2012 11:11 PM
PurpleNerple
Dec 17, 2010 08:12 AM
AZAudiA6Q
Nov 26, 2008 06:56 PM
projlightning
Jan 9, 2008 08:44 AM
rabenson
Jun 3, 2007 08:39 PM
