Question about DV
Old Jan 4, 2008 | 10:40 AM
fernieernie05's Avatar
Default Question about DV
I just bought a2000 A6 2.7T this week, before that I had an A4 2.8. I don't knowa whole lotaboutthe 2.7T enginebut I keep hearing about Diverter Valves. Can someone shed some insight asto what they do exactly and the pros/cons of buying a set. Any help is appreciated.
Old Jan 4, 2008 | 02:50 PM
daroshi's Avatar
Default RE: Question about DV
The DV's are mounted under the plastic engine shroud with the "V6 Biturbo" lettering. They divert any excess pressure from the high pressure side of the turbocharger plumbing back into the low pressure side. If the car still has the originals (plastic housing) you should replace them. Stock 710N DV's work just fine. Scroll down to the bottom of this page, $39.95 each http://www.ecstuning.com/stage/edpd/...ategory=Intake. The APR and Forge versions are pretty but are not worth the extra $$ IMHO.
Old Jan 4, 2008 | 03:01 PM
So the aftermarket ones are not worth the money? Why are the so much more what benefit are they over stock DVs?
Old Jan 4, 2008 | 04:32 PM
daroshi's Avatar
This article gives a very detailed description as well as test data: http://www.s4biturbo.com/art-dvtests.php
Old Jan 4, 2008 | 05:24 PM
ppgoal's Avatar
I agree that the OEM DVs should work well with a stock engine. But if you are ever going to chip your A6, you may want the heavier duty, higher priced DVs. I used Bailey's on my mechanic's suggestion.
Old Jan 5, 2008 | 11:52 AM
formulagigi's Avatar
N710s is the way to go!
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
