question about tiptronic
Old Jun 26, 2007 | 11:57 AM
98golda6q's Avatar
Default question about tiptronic
mine doesn't work anymore. i can put it over in the tip mode and go up and down all i want and nothing. tranny is perfect and shifts flawlessly, but i don't have the tip option anymore. i think i might have slammed it over or back too hard one day because it worked perfectly
Old Jun 26, 2007 | 12:48 PM
Jeffla's Avatar
Default RE: question about tiptronic
There are little magnets that are used to tell the transmission when you are in tip mode and that you are shifting. It is a common problem that the little magnet(s) fell out. Do a search for it and I bet you will find info on taking it apart and fixing it.
Jeff
Old Jun 27, 2007 | 02:37 AM
mustang196718's Avatar
^^^what he said. here's what you're looking for(below)...(picture credit to boston driver)
AND here's how to pull the cover and stuff off to get to it: http://www.audiworld.com/tech/int38.shtml
good luck, should hopefully just be a simple fix for you.
-mike
Old Jun 27, 2007 | 05:05 PM
vrso2's Avatar
i had same problem, but since i change all that part with magnets, everything works great !!
Whole change took around 30 min. I get it from EU by 50$ (approx.)
Old Jun 27, 2007 | 05:10 PM
vrso2's Avatar
here is a link with step by step, how to do it. http://forums.audiworld.com/a6/msgs/705947.phtml
Be carefull when remove shift ****. I did it wrong and that took me nex 30 min. to repair it
"Use soemthing like a paper clip or blade fuse to wedge in the groove on the bottom of the ****'s button so it does not retract into the ****. If you don't do that, it is a PITA to get back out!"
I didn't use any "paper clip" and that make me big problem to put one small spring back.
Old Jun 29, 2007 | 12:35 PM
98golda6q's Avatar
this is a hair above my level of comfort to do myself. thank you guys for the responses but i think i'm gonna have just an "automatic" for quite a while LOL...
Old Jun 30, 2007 | 09:05 AM
vrso2's Avatar
I love my TTronic. I can't drive without it
shane@tm
Nov 30, 2009 06:43 PM
SunnyShaida
Mar 18, 2009 04:12 PM
nyc2.7t
Mar 20, 2007 08:21 PM
DevilS4
Nov 28, 2006 11:23 AM
d_maniac
Jun 1, 2006 09:08 PM
