Questions about 01 2.8 purchase
Old Nov 16, 2008 | 01:04 PM
akielb's Avatar
Default Questions about 01 2.8 purchase
You guy's don't have any noob threads do you? I'm sure I could find something is the search would allow me to search for "2.8"
So I'm a 1.8t A4 guy so I have no idea about 2.8's and even less about A6's. A guy a work with is going to buy an 01 2.8 for his daughter. She doesn't need anything quick, just looking for something good. No idea about what price he's paying and how many miles are on it.
Any problems with the 01's? just usual ABS module, control arms ect??
What should a guy look for if he's looking one over?
-Thanks
Old Nov 16, 2008 | 01:19 PM
Jeffla's Avatar
The 2.8l a6 has all the same basic problems a 2.8l a4 has. Cam/valve covers, control arms... that's all I can really think of that is big.
Old Nov 16, 2008 | 02:16 PM
Retard Riot 686's Avatar
X2 what he said. Love my 2.8 just gotta do the maintenance that goes with the car and shell run forever. There are a few cars on this forum that are 2.8's with 170k+ on the clock
Old Nov 16, 2008 | 02:21 PM
oc_audica's Avatar
and cam seal leaks like to come up around +/- 80k
Old Nov 16, 2008 | 06:35 PM
2001A6's Avatar
Everything has basically been covered. I guess the only things left are typical Audi issues, hazzard realy, window switch thing ect.
Old Nov 17, 2008 | 10:40 AM
NH_USA's Avatar
170+ ??? LOL My 97 Avant just turned 202K and I'm expecting at least 300K.
My 200QT went 350K before I finally gave up (The car didn't) so in my mind 300K is conservative..
Old Nov 17, 2008 | 11:32 AM
hxgaser's Avatar
A6 with a 2.8 is a good car. Here is my list of things to look for.
1. Timing belt, water pump and related stuff. Make sure they are replaced.
2. Typical 2.8 oil leaks... valve covers, cam seals, cam chain tensioner seals.
3. Tie rod ends and control arms.
4. cam chain tensioners. Make sure the car does not sound like a diesel.
5. Window guides. Fronts are easy to replace, the rear ones require full replacement of the motor.
6. Transmission fluid and filter change. Definition of lifetime fluid is about 100K miles.
Old Nov 17, 2008 | 01:19 PM
oc_audica's Avatar
I should be hittin 200k in a couple mos =) on my 99 2.8
the most expensive job was the cam seal leak, covered under extended warranty 4 years ago. everything else has been wear & tear since then... 2.8 motor is solid, and my trans is holding up strong too *knocks on wood grain*
mr_byers
S8
Apr 27, 2016 07:23 PM
innov8
Oct 28, 2014 05:51 PM
Nikkormat
Apr 23, 2014 11:52 PM
peakpro
B8 Models
Feb 19, 2009 12:14 AM
RugbyDude
Aug 22, 2004 02:34 AM
