Radio/AC panel lights fade
Old Nov 7, 2005 | 06:13 AM
drlv's Avatar
Default Radio/AC panel lights fade
I am having problems with the lights on my radio/air con/etc. panel.
When I turn on my headlights, everything lights up on the panel but then goes off until only a handful of the buttons are actually lit up. I can get them to light up again by adjusting the fader, but then they go out again!
I've checked with my local dealer but he wants to take the car in for a few days to run diagnostics. Before I resort to that, has anyone else had a similar problem? Could it be a loose connection somewhere?
Thanks!
Old Nov 8, 2005 | 07:44 PM
NSX JR's Avatar
Default RE: Radio/AC panel lights fade
Sounds like your dimmer switch is going bad. Since it affects multiple lights I doubt they are all going bad. If you have a '02+ then button illumination is controlled over CANbus, which may be trickier to diagnose.
mawgui
Sep 16, 2012 08:18 AM
reiss
Apr 3, 2012 01:06 AM
jimmy154
Sep 11, 2007 02:51 AM
BigMikeLV
May 18, 2007 08:02 PM
ron gash
Sep 1, 2006 10:56 PM
