Radio problem
Old May 20, 2007 | 09:27 PM
bigeel0's Avatar
Default Radio problem
I have 2000 A6 2.8. The radio works fine, but the speakers go out and on in various modes. The woofer is always on. Example, when I turn on the radio in the morning, it runs go for about 30 minutes than the sound goes out and then cuts out throughout the day. Is the wiring wrong, short, antenna contact. Had a radio person work on it for $35.00, but he said the radio was good, it might be the wiring on the car. Any suggest people, or just get a whole set of new speakers, but its a bose. Any recommendation would be appreciated.
Old May 21, 2007 | 01:35 PM
votblindub's Avatar
Default RE: Radio problem
possibly the factory amps cutting out on ya?
Old May 21, 2007 | 07:08 PM
auditech79's Avatar
The factory Bose amp is the problem. (behind trim on the right side of the trunk i think) also check the connector.
Old May 22, 2007 | 12:25 AM
Houndz408's Avatar
Definately sounds like a bad amp or you could have a shorted speaker or speaker wire which is causing the amplifier to shut all four channels down. Did you mess with the car/ buy it used / etc?
Old Jan 10, 2008 | 07:35 AM
jan.hoj's Avatar
I have almost the same problem with my A6 from 2000.. but in my case its just the right back speaker.. sometimes its playing sometimes not.. i think its something with the wiring..
Old Jan 10, 2008 | 12:44 PM
NH_USA's Avatar
Listen to AUDITECH!!! ----- Well known Bose amp problem.
hlmorbit
Sep 29, 2012 08:25 AM
ffmist@hotmail.com
Aug 22, 2010 09:57 PM
amiddle104
Jul 21, 2010 04:14 PM
jan.hoj
Jan 10, 2008 07:31 AM
khaoswing
Mar 6, 2007 11:31 AM
