Rear Courtesy Lamps
Old Nov 1, 2007 | 08:14 AM
Mikesa6's Avatar
Default Rear Courtesy Lamps
The rear courtesy ceiling lamps do not work when the door is open. The individual reading lamps work fine. I have replaced the bulbs and also looked at the fuse and everything appears ok. Is there any other area I can check? It is a 2002 A6. Thanks for any assistance.
Old Nov 1, 2007 | 03:41 PM
JCMAC's Avatar
Default RE: Rear Courtesy Lamps
This may seem a bit juvenile but I am assumingthat you have already checked the A6 owner's manual regarding operation of all of the switches on the rear dome light as it may be possible switch off the door actuation by the dome light switch. I will check my Bentley manual later on today.
Old Nov 1, 2007 | 03:50 PM
Mikesa6's Avatar
The owners manual isn't very clear on the operation other than what the buttons and switch are for. I didn't see anything that would temporarily shut the rear light off. The courtesy lights under the front seats work well so if there was a switch that would turn out the rear lights, I would think it would also turn the lower lights off(?).
Thanks for the help.
Old Nov 1, 2007 | 05:21 PM
Awally6's Avatar
the rear courtesy lights have three positions. One position is "on" the next position is "off" and the last position is "on when doors are open". If you look close enough at the switches they have little pictures for each position.
this is how it is on my a6.... i could be wrong but, thats how mine works.
Old Nov 2, 2007 | 02:52 PM
rvt1000's Avatar
[quote]ORIGINAL: Awally6
Same here
Old Nov 2, 2007 | 03:45 PM
IzeBerg's Avatar
just some more info....my rear lights have a short in them...the reading lights work fine...i can take the whole assembly out and mess with the wires and the others work for awhile...i need to rewire the whole thing...but you might want to check that out on yours too.
Old Nov 2, 2007 | 03:48 PM
Mikesa6's Avatar
Thanks for the info. I must have some sort of a short so I'll pull the assy and take a look. Still no louck with the switch positions.
gabete
Nov 3, 2009 12:51 PM
danmcc86
Oct 12, 2009 11:07 PM
joesette
Feb 26, 2008 08:53 PM
Lazer Viking
Nov 14, 2006 09:25 PM
therippa
Feb 8, 2006 09:30 PM
